Author Topic: [SOLVED]Connection Issues  (Read 1582 times)
Offline Victor15Topic starter
  • Country: br
  • PCB Designer
« on: January 10, 2020, 05:43:47 pm »
Hello there!
I'm new in Altium, I'm using the 19.0.15 versions, only in this project it's happened, not in the others.
I've placed some components in the PCB, but need to change their position, it's ok, but the old connections lines still there, like the image:
https://drive.google.com/file/d/17RCE97s1K5TlMXfDpWxHXmOCztec3Sht/view?usp=sharing
Someone can help me with this? how to delete these lines?
« Last Edit: January 13, 2020, 12:11:32 pm by Victor15 »
Offline thm_w
  • Non-expert
Re: Connection Issues
« Reply #1 on: January 11, 2020, 01:24:30 am »
Did you already try 'Clear error markers'
Maybe Hide all nets then Show all nets, under view menu.
If it still persists may be necessary to copy the information to a new PCB file or similar.
The following users thanked this post: Victor15
Offline Bud
« Reply #2 on: January 12, 2020, 04:08:27 pm »
Do you have any components on the bottom layer and the bottom layer is turned off? Try turning on the bottom layer.
  • Country: br
  • PCB Designer
« Reply #3 on: January 13, 2020, 12:08:04 pm »
No, all the components are in the top layer, these markers whore about the last positions off then.
  • Country: br
  • PCB Designer
« Reply #4 on: January 13, 2020, 12:10:36 pm »
Thanks, Bro I really don't know the function "Clear error markers", thank you a lot!! it's worked perfectly.
About the Hide all, I tried this, but without success
