Author Topic: Altium Designer 20 - SVNDbLib Pin Mapping  (Read 1146 times)
Offline Elec27Topic starter
  • Country: at
« on: April 24, 2020, 10:09:49 am »
Hello,
I converted some Intlibs to SVNDbLibs and I am wondering if there is a Pin Map feature in database libraries like in Intlibs?
What do you do if you have eg. two dual transistor components which have the same package, but different pinouts?
In Intlibs it was easy, because I could change the Mapping between Schematic Pin Designator and Footprints Pin Designator.
My solution would be to create multiple footprints with changed Pin Designators. Is there a better solution?
Kind Regards
