Author Topic: Turn off grid / shading on printed schematics  (Read 1051 times)
Offline euzerTopic starter
« on: July 06, 2020, 10:03:06 am »
When I print a schematic (AD20) a fine dot grid (or shading) is applied, even if I turn the grid off under preferences in the schematic. The schematic itself was set to line grid (if I use it), so not sure if the dots I see on a print off are some light shading. How do I turn this off?
Thanks
Edit: Fixed - the RGB values weren't all 255 under properties->General->Sheet colour
My current problem is getting net junctions to print as filled solid when I select black and white printing - they're shown as just a outline. If I select colour or grey then the junction is filled but the wires are shown in a dithered non-straight style.
« Last Edit: July 07, 2020, 02:49:31 pm by euzer »
