Author Topic: Another newbie question - Supplier Information window  (Read 1967 times)
Offline HousemanTopic starter
« on: January 05, 2022, 06:24:37 pm »
Hi forum, and happy new year.
Another newbie question. I am following Feranec's tutorial (which I recommend) and in the schematic library panel hovering through components at the bottom there is a fixed window showing the supplier info of each component (see attachment). He is using AD18. I am using version 22.. I have found no way to show that info in AD22..
please help. Thank You
Best regards
Offline RadioAct
Re: Another newbie question - Supplier Information window
« Reply #1 on: January 11, 2022, 06:55:28 pm »
That panel have moved to the bottom of component properties on the right now under "Part Choices"
It works a bit differently, you click the Edit Supplier Links and it opens a new window where you can add the part associations
« Last Edit: January 11, 2022, 06:58:06 pm by RadioAct »
The following users thanked this post: Houseman
