Author Topic: Channel Offset Errors  (Read 14981 times)
Offline gvirbTopic starter
« on: April 11, 2015, 10:36:19 pm »
I have a sheet where I copied set of components a certain amount of times. Each set of components were assigned a property of ClassName with a unique class name for each set. From the PCB document's classes menu, I created a channel class consisting of all of the sets for which I want to copy room formats.
When I go to copy room formats from one the rest, I receive an error mentioning sequence errors. Any suggestion on how to correct the issue.
I am using version 14.3.
Offline Mikekoz13
Re: Channel Offset Errors
« Reply #1 on: April 13, 2015, 01:12:10 pm »
The attached document will explain it very well. Look at sheet 10 and work your way thru... it's pretty easy and takes only a few minutes.
The following users thanked this post: jn, aandrew
