Author Topic: SMD Pads in Altium  (Read 11417 times)
Offline sean0118Topic starter
SMD Pads in Altium
« on: May 26, 2015, 12:31:05 pm »
Hi everyone!  :D
If you place a pad in Altium Designer 14 it's through hole by default. I guess you could make it an SMD pad by setting the hole size and one layer to 0. But there must be a more elegant way right?
What's the correct method for creating an SMD pad in Altium?  ???
Offline 8086
    • Circuitology - Electronics Assembly
Re: SMD Pads in Altium
« Reply #1 on: May 26, 2015, 12:35:05 pm »
Change layer to top layer.
« Reply #2 on: May 26, 2015, 12:39:07 pm »
Ah, of course!  :D
(The right Altium setting is always in the last place you look  :D)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: May 26, 2015, 10:50:34 pm »
You wouldn't normally place pads on the PCB (library, yes!), but using them for SMT test points (instead of vias, which are obviously multilayer-only) is a protip. :)
Seven Transistor Labs, LLC
« Reply #4 on: May 27, 2015, 12:44:44 am »
Yeah this was for a library custom component, but that's an interesting idea to use them as test points.  :D
Offline Christopher
« Reply #5 on: May 27, 2015, 04:35:36 pm »
I do Test points as a library part so you can choose the net on the schematic
Offline T3sl4co1l
« Reply #6 on: May 28, 2015, 01:08:53 am »
Yeah, I like to do that too, so you get them during placement and don't have to scratch around for space later.  Sometimes that doesn't work out as well in the design though.
