Author Topic: Importing a DXF into Altium PCB Library.  (Read 8130 times)
Offline mrpacketheadTopic starter
  • D Size Cell
« on: May 18, 2014, 10:40:21 am »
I'm stuck, i'm trying to import a complex shape via a DXF into a component library ( to make a footprint ).  I can import a dxf into a pcb but not the component.  The options just not there to do it into a library.   IS there a way. I could draw it, in altium but its a lot of work, and i have quite a lot of things to draw, so looking for the 'better' way.
Offline David_AVD
Re: Importing a DXF into Altium PCB Library.
« Reply #1 on: May 18, 2014, 10:52:12 am »
Perhaps you can import into a temporary PCB then copy and paste into the library?
  • D Size Cell
« Reply #2 on: May 18, 2014, 11:06:54 am »
hey David, hows BNE.  I'll give this a try.
Offline David_AVD
« Reply #3 on: May 18, 2014, 11:14:34 am »
I haven't tested it, but I'm sure I've copied and pasted exploded parts from PCB to library before so that part should work.
  • D Size Cell
« Reply #4 on: May 18, 2014, 11:17:48 am »
Edited   thanks!  that seems to work fine.    Had to move the layers before i copied it though into the component library..
It does seem like quite a work around, you'd think you could import directly.
« Last Edit: May 18, 2014, 11:47:38 am by mrpackethead »
