Author Topic: Copy & Paste PCB layouts  (Read 2989 times)
Offline ChristopherTopic starter
« on: January 05, 2015, 06:19:01 pm »
I have a schematic and PCB designed, and I need to make a copy of this same layout on the board 8 times, with the inputs and outputs going to one place.
How can I do this with Altium? I've heard about Rooms but am unsure of exactly what the best practice is for this.
Offline free_electron
    • SiliconValleyGarage
Re: Copy & Paste PCB layouts
« Reply #1 on: January 05, 2015, 07:27:26 pm »
rooms are not how that is done. look up tutorials on 'channel design' for altium.
you will create a toplevel schematic, create 8 instances and place the connectors on top level. altium will partition your deisng in blocks you can manipulate. you can clone placement and routing between blocks.
