Author Topic: Serious flaws in 3d rendering in Altium, anything but simple folds.  (Read 2640 times)
Offline mrpacketheadTopic starter
  • D Size Cell
The 3D features of allium are actually pretty useful. I've been using them to be able to create 3d models so mechanical can do their magic with cases etc;
Most recent board has some more complex board cut outs and fold zones for flex, and allium really spits the dummy, the result is boards that don't fold..  Have raised a case with Altium and they adivse;
"this is a limitation of allium, it doesn't recognise the geometry of the board".. Sigh, if its good enough to be able to draw it!
I can produce the actuall working gerbers ok, but Im going to have to model the 3d bits as a separate process.  and that is sort of non trivial!
Offline RF-Tech
Re: Serious flaws in 3d rendering in Altium, anything but simple folds.
« Reply #1 on: January 05, 2015, 02:57:19 pm »
I recently designed a rigid-flex board with multiple bends, and was able to create a step with it in the folded configuration and import it into solidworks without any problem.....but one.....I had placed a 9 pin connector on a section of flex that was to be flexed (bent), and it was not able to do it.  Once I removed the connector, which was not meant to be on a flex section it worked correctly.
  • D Size Cell
« Reply #2 on: January 06, 2015, 08:15:43 am »
sadly not my problem.   I'd not even put components on the board!
