It is also your chance to fuck them up the same as anyone else.
I am amazed how many people think they are the only ones who can create a correct library part. If you take and check someone else's library then a mistake requires two or more people to fuck up and there is a chance whoever made the library has proven the part in a design.
Assuming you can find a preexisting library that includes the part you want to use in the first place. The point is that people can spend more time looking for a library part and have nothing to show for it compared to the time it would take to make the part themselves. Sure, if you can find a library that has the large pin-count, tedious-to-make part you want to use, then great - by all means double check it and use it.
But if you're making the part from scratch, I can't think of a good reason why you wouldn't want to link supplier data to the part if you could. It literally takes a few mouse clicks. I can double click the schematic symbol for any component in my design and have the part parameters visible within Altium.
