Author Topic: Is it worth updating Altium from 19 to 23?  (Read 845 times)
Offline JohnGTopic starter
« on: June 29, 2023, 10:12:00 pm »
I know, it's one of "those" posts...
I have been using Altium 19 on a permanent license since it was released, though I have had the opportunity to update it at any time. That opportunity may go away, and I am wondering if there are good reasons to stay on 19 versus upgrading to 23 while I still can. I already have some reasons to upgrade, but they are not very strong or I would have done it already.
Thanks in advance.
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Is it worth updating Altium from 19 to 23?
« Reply #1 on: June 30, 2023, 04:45:43 pm »
I always found 18 to be the buggiest version of AD things have gotten progressively better with each release in regards to stability.
Honestly it is worth upgrading just for the net selection eyedropper which I don't think was in 19, but I might be wrong.
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: JohnG
Offline PlainName
  • Country: va
« Reply #2 on: July 01, 2023, 11:32:11 am »
The draughtsman document is worth upgrading for. Not sure if it was in 19 but there were vast improvements in 21/22 so even if you have it, the current version should be much better.
