Author Topic: Altium 23.6.0 schematic template use reference project parameters  (Read 1008 times)
Offline pryanbengTopic starter
Is there a way to make schematic templates reference the project parameters rather than document parameters? I've had a multi sheet project and to update the revision number I am manually changing the parameter on each sheet. Currently the text field on the template I have set to =Revision
Draftsman by default uses the global parameters under Project options, is there a way to point a schematic template at the project parameters rather than the individual document parameters.
Offline ajb
Re: Altium 23.6.0 schematic template use reference project parameters
« Reply #1 on: July 04, 2023, 09:34:06 pm »
Yes.  If you have a `Revision` parameter defined at the project level, then setting the `Revision` parameter at the sheet level to an empty string should cause it to inherit the value of the project level parameter.  Alternatively, you could define a different project level parameter, call it `ProjectRev`, and either use that directly in your templates, or set the sheet level `Revision` parameter to `=ProjectRev`.
I believe this behavior is actually consistent with Draftsman, but maybe Draftsman docs don't have a system parameter called `Revision` at sheet level by default, or maybe it defaults to a blank string instead of the usual "*".
The following users thanked this post: pryanbeng
Offline thm_w
  • Non-expert
The following users thanked this post: slothsd
« Reply #3 on: July 04, 2023, 09:55:30 pm »
Ah I did not realize it would auto inherit. Thanks!!
