Author Topic: Greek alphabet in the schematic editor.  (Read 1834 times)
Offline MikePTopic starter
  • Country: ua
« on: March 09, 2023, 06:55:16 am »
   Hello friends.
  Colleagues are asking for help. Yes, Greek characters - \$\Omega\$. Actually many letters are needed.  :)
  I have read several discussions here. Unfortunately no solution has been found.
  The essence of the problem: after closing the document, all Greek characters turn into "?".
  Is it possible to use the Greek alphabet or is it fundamentally impossible?
  Thanks.
Online JohanH
Re: Greek alphabet in the schematic editor.
« Reply #1 on: March 09, 2023, 08:19:59 am »
This sounds like a code page issue. Try to install Greek letter support in the system? At first you should consult Altium, it's anyway a commercial product that should offer support.
There is also the distinction between Unicode Greek capital omega (Ω, U+03A9) and the Unicode electrical ohm symbol (Ω, U+2126). The latter is rarely used (AFAIK), but you could try if there is a difference.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #2 on: March 09, 2023, 02:07:52 pm »
Not all fonts support greek characters.
I have never seen the problem you are having though.
Side note, I always use alt+234 for Ω, alt+241 for ±, alt+230 for µ, and alt+0176 for °. Those are all the symbols I typically run into and therefore have memorized.
“They Don’t Think It Be Like It Is, But It Do”
Offline Fgrir
« Reply #3 on: March 10, 2023, 03:24:07 pm »
Works fine for me here using Arial font, and it looks fine even after closing and reopening Altium. I know from past experience with files shared between different computers that Altium will silently substitute fonts if it can't find them. Are you having a problem on the same machine where the strings were originally placed?
  • Country: ua
« Reply #4 on: March 11, 2023, 08:14:49 am »
 Thank you all for your help.
 The problem is in the same computer. As far as I understood the characters disappear even without closing the program - just closing and opening the document does it.
 I passed the information on to my colleagues. They tried digital combinations - there is a mistake.
 The examples you provided look like this:
Alt + 03A9 or 2126 – N
Alt + 234 – е with some feature
Alt + 241 - ъ
Alt + 230 -ё
Alt + 0176 - °
 These are Cyrillic characters.
 In addition, the font SYMBOL was found. It contains exclusively Greek letters that do not disappear. But in one inscription it is impossible to combine Greek and other letters.
 Most likely the problem is in the settings of symbol tables, but so far no solution has been found.
Offline Pseudobyte
« Reply #5 on: March 13, 2023, 02:58:00 pm »
I should add that I am using the US - English keyboard layout on windows. Your locale settings might change your alt-codes.
Offline ajb
« Reply #6 on: March 13, 2023, 09:16:10 pm »
In Win10/11 you can access special characters through the emoji keyboard, which is Winkey+':' .  This works more reliably in more applications than Alt codes IME, and is likely more universal in terms of selecting a suitable codepoint regardless of local language settings.  Also you don't have to remember what codes are what.  Recently used characters will show up on the history page, so you won't have to dig through the whole list every time.
The following users thanked this post: maxpayne, thm_w, Pseudobyte
