Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Using Multiboard with non pcb components
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Using Multiboard with non pcb components (Read 1721 times)
ahbushnell
Frequent Contributor
Country:
on:
August 23, 2020, 04:51:21 pm »
I started working with the multiboard tool in Altium. It looks handy. I would like to be able to connect external components that are not PCB's. Is there a way to do that? For instance a commercial power supply.
Thanks
Andy
Logged
ahbushnell
Country:
Re: Using Multiboard with non pcb components
Reply #1 on:
August 27, 2020, 03:32:24 am »
I'll answer my own question. It looks like you can only connect boards together. To bad. Maybe that will be in release 21.
Logged
Berni
Super Contributor
Country:
Reply #2 on:
August 27, 2020, 05:17:26 am »
If you want to use the multiboard workflow to put a power supply into your design then just make a tiny board that is hidden inside a 3D step model of the power supply, then import that.
Logged
ahbushnell
vikebo
Newbie
Country:
Reply #3 on:
October 02, 2020, 07:58:11 am »
Not sure if it has been added later, but I'm using 20.1.14 and have "Insert STEP Part..." available when assembling the boards in .MbaDoc.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
