Author Topic: Duplicating PCB layout without screwing up schematic  (Read 2689 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: June 17, 2014, 06:01:47 am »
I have four different parts to a circuit and I can use the same layout for each one. In the schematic I just copy pasted the circuit four times, then I reset duplicate designators and its great.
In the PCB layout portion of the program I laid out one of these circuits. I can also copy&paste it three times, but then it won't agree with my schematic.
Is there any easy way to do this? Or do I need to copy&paste it three times and manually rename every part?
Offline kiran_shrestha
  • Country: kr
  • Kiran
    • shorted wire
Re: Duplicating PCB layout without screwing up schematic
« Reply #1 on: June 17, 2014, 11:06:29 am »
I think you have to try component link... sub menu available in Project menu.
Thats all
Offline Bassman59
  • Yes, I do this for a living
« Reply #2 on: June 17, 2014, 07:28:22 pm »
Encapsulate the circuit to be duplicated into a schematic subsheet, and either instantiate it four times in a higher-level sheet, or use the "Repeat" directive on the sheet when instantiating it in the higher level.
Then use Rooms to duplicate the layout.
