Author Topic: Multichannel design NetClass  (Read 2402 times)
Offline aleks223Topic starter
« on: December 12, 2016, 02:19:05 pm »
I'm wondering how to set different NetClass for each channel of a Multichannel design, where REPEAT(..) is used to create diplicate sheets. The idea is then to set different rules for nets within the same NetClass and between nets of different NetClass as they are at different potentials.
Offline technotronix
    • PCB Assembly
Re: Multichannel design NetClass
« Reply #1 on: December 30, 2016, 09:59:36 am »
I like the idea but don’t know much about implementation. Can you give some more about multichannel design netclass?
