Author Topic: Altium prints garbage  (Read 7244 times)
Offline PlectoTopic starter
« on: July 25, 2017, 07:38:44 am »
Hi. If I try to print a circuit board with altium I get this:
Printing schematics works fine and I haven't had any problems printing from any other program. What is the reason for this?
Offline M4trix
  • Country: hr
Re: Altium prints garbage
« Reply #1 on: July 25, 2017, 08:16:41 am »
Looks like Altium has a good sense for art and abstract painting !  ;D
Did you try to export the pcb files in PDF ?
Offline tszaboo
« Reply #2 on: July 25, 2017, 09:47:43 am »
Altium has very bad printing interface. I had the software crashing because I dared to click the print preview button, and my printer current printer wasnt a standard printer but a laber printer. It defaulted to that, and then crashed. Nice.
Anyways, check the print preview button. Right click, and go to "configuration". That is the first step, and restarting the software, closing all the other open project, freeing up memory. It shouldnt be this way, but it is.
Offline ajb
« Reply #3 on: July 25, 2017, 11:54:56 am »
I've had the opposite problem, where printing a schematic from Altium crashes the printer!  In fairness to Altium, HP bears some blame for that one, but printing the same schematic to PDF and then printing the PDF works just fine.
Generally I just print everything from Altium to PDF, mostly via OutJobs, and that usually works fine and gives a bit better control.
« Reply #4 on: July 25, 2017, 02:17:07 pm »
Outputting to PDF works, but how do I scale it so that the board has the correct size?
« Last Edit: July 25, 2017, 02:41:46 pm by Plecto »
Offline M4trix
  • Country: hr
« Reply #5 on: July 25, 2017, 03:51:44 pm »
Go to --> File --> Page Setup. You can do the fine adjustments there.
« Reply #6 on: July 26, 2017, 03:29:30 pm »
That didn't seem to work. Even though the scale was set to 1.00 the PDF was still big enough to need two A4 pages to print. The PCB is only 10x6cm :\
Offline floobydust
« Reply #7 on: July 26, 2017, 03:48:08 pm »
I've had Altium printing problems after IT department did (OS) Windows 7 update.
Fix was to uninstall and reinstall the printer in Windows.
Offline M4trix
  • Country: hr
« Reply #8 on: July 26, 2017, 07:02:37 pm »
Hm... what about the Adobe printer settings ?
@floobydust,
that's why I never print directly from Altium Designer.  :-BROKE
Offline floobydust
« Reply #9 on: July 26, 2017, 07:32:39 pm »
I've seen OP's thing once before, I hardly remember but the PCB origin/size/units were not set properly and that error carried over to the print job. Maybe I resized the damn room.
I wonder if it looks OK in the Gerber viewer.
I love printing directly from Altium designer. That way I get to take a long walk over the colour laser-printer in the next building and find... it's monochrome, a page is missing, big fat border appeared, did not rotate to landscape, wrong paper size, damn yellow ERC markers are everywhere, etc. etc.
It's the only way to get exercise  :-DD
« Reply #10 on: July 27, 2017, 05:57:31 am »
Adobe Reader settings was set to letter as paper size, but not much changed by changing it to A4. I just exported gerber files and sent them to a board house. They seemed fine even though I was a bit worried that the board house interpreted my board to be a little bit smaller than it actually is, but they did mention that their measurements can be thrown off by various things. I'll make a new board with only one component and see how that works :)
Offline plazma
    • Homepage
« Reply #11 on: July 27, 2017, 06:18:39 am »
Frame it and put it on the wall :)
The following users thanked this post: Pack34
Offline Pack34
« Reply #12 on: July 27, 2017, 05:29:42 pm »
Any luck exporting that as a PDF? I half-heartedly want to hang that in my office at home.
Offline ddavidebor
    • Smartbox AT
« Reply #13 on: September 07, 2017, 01:15:34 am »
Try printing through draftsman pdf exports if you have altium 17
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
