Author Topic: Drawing Guard rings in Schematic  (Read 3629 times)
Offline nnsTopic starter
« on: December 07, 2016, 02:58:39 pm »
Does anyone have a "nice" way of drawing guard rings in Altium schematic capture?  I like my schematics to clearly convey what's going on, so drawing a guard ring like:
Is attractive to me.
I can use line segments (and set them to dashed), or I can use a blanket directive (basically a dashed polygon). The blanket directive has the added benefit of being able to put the guarded nets into a class (helpful during PCB layout), but has the drawback that the dashed line looks a little crappier than the line segments. With both of them, I can't clearly show the guard net "attached" to the blanket directive (the wire just ends touching the directive/line, instead of with a node marker like in the drawing above).
For now, it works.  I'm just wondering what other people do and if there is a better/more standard way to show this in Altium.
Offline Miles Teg
  • YAWP!!!
Re: Drawing Guard rings in Schematic
« Reply #1 on: December 07, 2016, 04:57:14 pm »
Hello,
I should have bring another net and using the netcolor on it.
If you see me running, that's already too late.
Offline ajb
« Reply #2 on: December 07, 2016, 06:00:05 pm »
You can change the visual style of the blanket to suit, and you can place a manual junction to show that the blanket outline is 'connected' to the guard net.  Does that get you what you want?
« Reply #3 on: December 08, 2016, 12:47:53 pm »
Somehow I managed to totally miss the manual junction object for 3 years. Wow. Thanks for pointing out my (obvious) oversight!  |O
I think that solution will result in the best look of the final schematic.  Thanks!
That's a good idea, however for my needs, I think I prefer a dashed line solution. I believe it's more obvious when printed black and white.
Offline Miles Teg
  • YAWP!!!
« Reply #4 on: December 08, 2016, 04:56:54 pm »
I understand, but still believe getting the right color to have a easily indentified different grey from the black nets in grey scale printed schematic could be usable.
Hope you will find also the optimal solution with dashed lines.
