Author Topic: SamacSys component search/install plugin for the Altium Designer  (Read 3124 times)
Offline hesam.moshiriTopic starter
    • MyVanitar
I use the Altium designer to design PCBs. Recently I found a very interesting plugin which can be installed and used inside the Altium designer. I am able to search for the components and install the libraries in the Altium and use them instantly in the project.
Designing the schematic and footprints libraries are time-consuming and tedious tasks, which reduces the productivity of a designer because it is a routine procedure for every new component that brings fatigue and sometimes nervousness. Therefore, at least it helped me a lot, so I decided to share it here
https://www.samacsys.com/altium-designer-library-instructions
it has been produced by a company named SamacSys, which is located in London-UK. The component database/search engine contains more than 15 million parts and all services of this website are for free. even if you could not find a specific component, it can be ordered to be designed for free!
« Last Edit: March 04, 2019, 07:23:58 am by hesam.moshiri »
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: SamacSys component search/install plugin for the Altium Designer
« Reply #1 on: March 03, 2019, 10:32:25 pm »
Neato
I am a bit paranoid so prefer to make SCH/PCB symbols/footprints myself. To make PCB footprint gen a bit easier I use this: https://www.pcblibraries.com/
Offline DerekG
  • Country: nf
« Reply #2 on: March 03, 2019, 11:17:40 pm »
I assume you do not have a current Altium subscription?
If you do the fastest way is to access the Altium Vault for your component needs. The footprints from the vault have been rechecked for accuracy by an engineer.
I also sat between Elvis & Bigfoot on the UFO.
    • MyVanitar
« Reply #3 on: March 04, 2019, 07:20:05 am »
Neato
Actually, all services of this website are free. it contains more than 15 million parts currently
Offline ddavidebor
    • Smartbox AT
« Reply #4 on: March 09, 2019, 05:44:46 pm »
I've tried it but was never satisfied by the footprint quality and ability to set it up.
I also recommend pcblibraries. In general, always check on octopart if the component has a model, they're very good.
Davide
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
