Author Topic: Not-fit of a component in all channels in a multi-channel design  (Read 1019 times)
Offline ricko_ukTopic starter
« on: December 01, 2020, 05:43:56 pm »
In a multi-channel design, if you want a specfic component to be NOT fitted on ALL channels, it looks like you have to go into every channel and mark it in every single channle as not fitted.
Is there a way to select that part in the "main" sheet schematic and set as not-fitted for ALL channels?
Thank you :)
