Author Topic: Altium help needed, board cutouts not showing on JLCPCB website  (Read 5573 times)
Offline RutgerTopic starter
« on: September 30, 2019, 11:10:42 pm »
I am trying to upload a panel of Tubescreamer (famous guitar pedal) clones I made in Altium, but for some reason the inner cut-outs are not coming through.
Any suggestions on what I should check/do in Altium or should I contact JLCPCB about these cutouts.
Thanks.
« Last Edit: September 30, 2019, 11:23:36 pm by Rutger »
Offline cgroen
    • Carstens personal web
Re: Altium help needed, board cutouts not showing on JLCPCB website
« Reply #1 on: October 01, 2019, 08:33:34 am »
When I send boards to JLCPCB with internal cutouts, I do the cutouts in the keepout layer, and I also put the text "CUTOUT" inside the cutout area (the text is also on the keepout layer)
I also write a remark to the order that they need to watch "cutouts" in the design.
Works every time
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #2 on: October 01, 2019, 01:50:28 pm »
Are your cutouts included in your board outline gerber?
“They Don’t Think It Be Like It Is, But It Do”
Offline cgroen
« Reply #3 on: October 01, 2019, 02:05:42 pm »
Yes, they are in the gerber, see below
Offline JackJones
« Reply #4 on: October 01, 2019, 02:18:03 pm »
Their gerber viewer is just really buggy, I have the same issue with boards made with Kicad. As long as it shows the cutouts correctly with other viewers it should be fine.
The boards I have ordered have come out correctly despite their viewer showing no cutout.
Offline cgroen
« Reply #5 on: October 01, 2019, 02:21:39 pm »
Same here, as soon as you make something that isn't a standard square board, their viewer fucks up!
Offline Pseudobyte
« Reply #6 on: October 01, 2019, 05:21:12 pm »
I was talking to OP. I think you calling it keepout confused me.
Offline cgroen
« Reply #7 on: October 01, 2019, 06:04:55 pm »
Ah yes, its not me calling it that ;) The file is the .GKO which stands for Keepout Layer.
Offline Pseudobyte
« Reply #8 on: October 01, 2019, 07:58:35 pm »
Yeah Altium users would typically put their board outline on a mechanical layer like GM1. Altium is phasing out keepout.
« Reply #9 on: October 02, 2019, 01:36:36 am »
I put the cutout in the 'keep-out' layer as suggested (with text) and it seems to work, thanks for the tip.
Initially it did not show up after the upload, but when I went to the online gerber viewer it seems to be a black area.
