Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Red arrow vs green arrow from Output to Output container - using variants
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Red arrow vs green arrow from Output to Output container - using variants (Read 1485 times)
VermontEE
Contributor
Country:
on:
April 23, 2020, 12:52:58 pm »
I have a design that has a number variants. These are not variants of a footprint but a variant of a populated value, i.e. 0.10Ω vs 0.12Ω. When attempting to create the outjob, the arrow that routes from the output to the output container is red rather than green. A search for "outjob red arrow" gave this explanation
When defining variant usage at the individual output level, if the chosen variant does not allow the variation of fabrication outputs and the variant is specified for use with a fabrication-based output, the variant entry in the OutJob will be red, and a hover-tip used to flag the situation. Generation of output using the chosen variant will proceed as though the setting [No Variations] had been chosen. In other words, the base (non-varied) design will be used as the source of the output instead.
https://www.altium.com/documentation/altium-designer/preparing-multiple-outputs-in-an-outputjob-ad?version=18.1
If I go to Project->Variants and click on a variant then click on Edit Variant, the check box for 'Allow variation of fabrication outputs' is checked So I don't think this is issue
Why is the arrow red? How do I fix it?
Last Edit: April 23, 2020, 12:58:26 pm by VermontEE
Logged
ANTALIFE
Frequent Contributor
Country:
( ͡° ͜ʖ ͡°)
Re: Red arrow vs green arrow from Output to Output container - using variants
Reply #1 on:
April 24, 2020, 12:20:20 pm »
Do you get any warnings/errors when you compile the project?
Also, try resetting your Project Error Reporting (in Project Options), compiling again, and seeing if any warnings/errors pop up
Sounds like something is broken in your variant
Logged
https://www.antalife.com/
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
