Author Topic: Graphic does not appear in generated PDF  (Read 742 times)
Offline DartherickTopic starter
  • Country: do
« on: February 27, 2023, 11:46:11 am »
Hi everyone.
I created a draftsman document with some views and graphical (images) and every time I generated the output file (.pdf). the images do not appear in the pdf.
Offline mariush
Re: Graphic does not appear in generated PDF
« Reply #1 on: February 27, 2023, 12:40:07 pm »
The viewer you use to open PDF files may not support the image format inside the PDF (pdf supports some ancient black and white compression methods from faxes, or maybe JPEG2000 format)
inspect your document in adobe acrobat viewer or some other fancier pdf viewer
  • Country: do
« Reply #2 on: February 27, 2023, 01:01:23 pm »
I'm actually using adobe acrobat pro, which is fancier than the viewer.
I also tried it with other viewers with 0 results.
