Author Topic: Placement rules  (Read 3962 times)
Online tszabooTopic starter
Placement rules
« on: November 23, 2021, 05:09:17 pm »
I've noticed 1-2 versions ago, that there are new placement push and shove rules applied. So I cannot place components to close to each other. And it still applies, after I turn off the rule. It seems to be completely broken with anything that is rotated by 45 degrees.
How do I make it stop?
Offline thm_w
  • Non-expert
Re: Placement rules
« Reply #1 on: November 23, 2021, 09:48:13 pm »
Can you show a screenshot?
Are you using a 3D body for the part to correctly define it?
Re: Placement rules
« Reply #2 on: November 25, 2021, 03:07:15 pm »
It would probably be a video.
I have 3D model for each part.
Re: Placement rules
« Reply #3 on: November 25, 2021, 03:18:59 pm »
Found it, this was driving me crazy. It's in: Interactive routing/Dragging/Component pushing
This is not routing, this is component placement! :wtf:
