Author Topic: jobout file help  (Read 1565 times)
Offline gogomanTopic starter
jobout file help
« on: October 26, 2018, 05:15:12 am »
Hi  It's a challenge to generate pdf and setting up a job file.  Can some explain how to print each layer on a separate sheet.
the other problem is the  tittle block is mirrored when the bottom layer is printed, how can this be fixed?
If someone has a template which they would not mind sharing, it would be a great help.
thanks
Offline julianhigginson
Re: jobout file help
« Reply #1 on: October 28, 2018, 04:38:05 am »
I assume you're talking about printing a PCB document?
rather than doing a "pcbprint" from the outjob, these days you'd be better off setting up the drawing in draftsman, and then printing the draftsman document from your outjob.
Draftsman is actually very useful, and I found it had a pretty minimal learning curve once I decided to start using it.
« Last Edit: October 29, 2018, 06:20:45 am by julianhigginson »
« Reply #2 on: October 29, 2018, 01:06:15 am »
I figured it out,  but I wish it was better documented.
I'll look into draftsman
thanks f
