Author Topic: silly ad?  (Read 3191 times)
Offline FrankBussTopic starter
    • Frank Buss
silly ad?
« on: August 05, 2015, 10:16:45 am »
Today I saw this ad in Facebook:
What does it mean? You can do small hobby boards with it, with lots of bodge wires? And why the screwdriver? Testing the board if it can survive random short-circuits?  :-/O
Offline Gribo
Re: silly ad?
« Reply #1 on: August 05, 2015, 11:55:28 am »
Never pick random stock photographs from the internet? Lazy marketing drones?
I am available for freelance work.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: silly ad?
« Reply #2 on: August 05, 2015, 12:52:10 pm »
Please use our incomplete DRC, re-route missing wires afterwards with blue low resistance wire!
Now 30 Days for free!
    • Frank Buss
Re: silly ad?
« Reply #3 on: August 05, 2015, 01:24:49 pm »
Found the same image with Google image search, but without the wires and the screwdriver at shutterstock. So did they ask the designer to add the screwdriver and the wires? Sheng Teng uses the same image.
Offline ajb
Re: silly ad?
« Reply #4 on: August 05, 2015, 02:28:31 pm »
I believe I've seen that as part of an animated ad where they're trying to show what you can avoid by using AD.  Not sure why it appeared on its own, as out of context it does look rather dumb.
    • Frank Buss
Re: silly ad?
« Reply #5 on: August 18, 2015, 04:43:57 pm »
Just for the lols, the image is updated:
Looks like a low complexity (like single-side PCB voltage regulator) wet PCB, with a band-aid on the right side :-DD
I wonder how much they pay to create and push all these ads on Facebook.
