Author Topic: Bottom Layer Polygon to Bottom Overlay  (Read 3680 times)
Offline klemaTopic starter
« on: August 31, 2015, 04:33:21 pm »
Hello everyone
how copy bottom polygon to bottom overlay?
Piotrek
Online T3sl4co1l
    • Seven Transistor Labs
Re: Bottom Layer Polygon to Bottom Overlay
« Reply #1 on: August 31, 2015, 05:34:33 pm »
Convert polygon to region,
Change region's layer to overlay.
There's no way to have it update automatically (when repouring the polygon).  This must be repeated manually (or via script, I suppose).
Edit:
Specifically, it looks like you can't just convert (Tools / Convert / Create Region from Selected Primitives), because a poly isn't primitive.  Try:
Select polygon
CTRL+R, click twice (makes a copy)
Make sure the copy has the same attributes (if auto-repour is on, the poly will be empty)
Tools / Convert / Explode Polygon to Free Primitives (this converts it to a Region)
get Region properties, set layer to Overlay.
« Last Edit: August 31, 2015, 05:41:55 pm by T3sl4co1l »
Seven Transistor Labs, LLC
Offline armandas
  • Country: jp
    • My projects
« Reply #2 on: August 31, 2015, 05:54:15 pm »
Paste Special (E-A) seems to work on 14.3.
« Reply #3 on: August 31, 2015, 06:37:55 pm »
Thanks T3sl4co1l
Online T3sl4co1l
Offline armandas
  • Country: jp
    • My projects
« Reply #5 on: August 31, 2015, 07:31:22 pm »
Does it save clearance voids?
Just tried it and it does not keep any voids. It makes sense, since it's just a normal polygon drawn on a different layer.
