Author Topic: problem with adding pins to nets and adding component class members  (Read 3152 times)
Offline fateme mrbsTopic starter
why do i not get Add component class numbers and Add pins to nets checked, while validating changes from my schematics to PCB? everything seems to be correct :-\ :-\
i only get the add components checked! ???
i attached the pdf of that schematics and  a screenshot of Engineering change order window.
« Last Edit: May 15, 2015, 06:55:12 pm by fateme mrbs »
Offline ajb
Check your component links, and that the correct footprints are present in the PCB.
