Hey everyone... I'm new here and just looking for some hints on a time saver. I'm able to accomplish everything I need, but I'd like to eliminate a few steps and save a little time. This is something I think Altium should be able to do automatically, but instead it requires extra manual work... at least as far as I know. Hopefully someone will surprise me.
Anyway... does anyone know if there is a method to create a clearance rule for polygon pours that results in an automatic clearance from the board edge or any internal board cutout regions?
For instance with board cutouts, I have tried creating a clearance rule like that uses 'InPolygon' and 'IsBoardCutoutRegion', but that will still pour the polygon right up to the cutout region; which will result in a DRC clearance error. So I typically add a polygon cutout with my desired offset (or possibly a keepout in some cases) around the board cutout. This works fine, but if you decide to change the offset later, it requires you to redraw/edit the cutout/keepout, as opposed to changing a single clearance number in the rules. I'm not sure why the 'IsBoardCutoutRegion' query will not work for polygon clearances.
Same thing with the board outline... I typically just draw my polygon with the desired offset off the board edge or add a keepout, but it would be nice if there was a rule that took care of this. Again, I tried to use 'IsBoardOutline' in my rules, but that doesn't work. So is there anyway to use the "IsBoardOutline" query for this at all, or I am stuck using my current methods?
FYI.. I'm using Summer '09 release (9.3). Maybe this is addressed in newer releases??
Anyway, any help or advice is appreciated. Thanks.
