Author Topic: Project Explorer like interface in Altium?  (Read 1933 times)
Offline Pack34Topic starter
« on: March 30, 2017, 01:53:57 am »
One of the only things that I like in PADs is the project explorer. Wherein it's just a simple drop-down list that lets you select and highlight any component or net in the schematic or layout.
Is there something similar in Altium? Or at least a "Show @ C5" command like in Eagle?
Offline voltsandjolts
Re: Project Explorer like interface in Altium?
« Reply #1 on: March 30, 2017, 08:07:12 am »
1/Navigator panel
2/Cross probe with Split screen SCH/PCB
3/Query:  InPart('C9')
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: March 30, 2017, 12:40:15 pm »
And PCB List Panel (limit list to just: Components).
And J, C (Jump / Component), enter designator (e.g. C9, ENTER).
Seven Transistor Labs, LLC
Offline ajb
« Reply #3 on: March 30, 2017, 03:07:42 pm »
There are a number of different ways to do something like what you'be described.  In addition to the above:
PCB and SCH filter panels are very flexible, but a bit cumbersome.
The filter toolbar in the PCB editor gives you three dropdowns, one to select by designator, another to select by net, and another that gives you a list of recently used filter queries.  It's really just a set of shortcuts into the PCB Filter system.
The PCB panel lets you drill down by class into nets, components, 3D bodies, etc.
« Reply #4 on: March 31, 2017, 10:21:43 pm »
Thanks guys!
