Author Topic: Here is my first board I designed in Altium as a trial.  (Read 4791 times)
Offline thomasb9511Topic starter
« on: December 25, 2016, 08:50:12 am »
Hey everyone,
I use Eagle for pcb work for school but I was advised to try Altium Designer for some of my more advanced circuits. Things are different but this ain't Eagle, and I enjoy Altium Designer much more for some reason.
This is a board I designed as an FTDI FT232RL breakout, any input would much appreciated. Nothing was auto-routed or auto-placed:
https://drive.google.com/file/d/0BxflnOkuXYUQOTRqQ2lhMFBkNTA/view?usp=sharing
One question, the fact that USB is a differential signal in this design, is it OK if the lengths aren't terribly matched? I did try to routed the differential as short as possible and length matching isn't happening when I try to use on those traces(it because of the shortness of the traces?)
P.S. the Google drive link is due the file size limits of the file uploader
Offline Fortran
Re: Here is my first board I designed in Altium as a trial.
« Reply #1 on: December 25, 2016, 10:31:16 am »
Looks pretty good.  :)
D1 and D2 are backwards, and I'm not sure if the reset pin can be floating.
Push some traces so they don't come off the pads in an angle.
No you don't need the USB to be length matched in this case.
The reason you can't get it to work is either that it's too short and constricted, or it's not properly set up. Length matching in Altium is black magic. It only seems to work when I don't know why.
You could however make those tracks 10mil too. Wider then the pads looks kinda off.
« Reply #2 on: December 25, 2016, 11:00:28 am »
RESET# can be tied to VCC or left unconnected if not being used. - per the manual
Would it still a good idea to tie up to VCC even though?
Offline Fortran
« Reply #3 on: December 25, 2016, 11:27:59 am »
If the datasheet says unconnected is fine, then it's just fine as is. :)
Not all IC's like floating resets though, so a mindset of always pulling it to its intended state might save you some headache in a different project.
« Reply #4 on: December 25, 2016, 12:18:10 pm »
On a side note, if something is active low like the reset pin on most ICs it means low effectively turns on the the reset circuit, right?
Also here is an updated zip: https://drive.google.com/file/d/0BxflnOkuXYUQSlFrbGtubm1ZcVk/view?usp=sharing
Offline Fortran
« Reply #5 on: December 25, 2016, 12:47:26 pm »
Correct.
Active low are usually typed as #RESET, RESET# or with an overline.
In Altium, you can do the overline by putting \ after each letter, R\E\S\E\T\
Offline Fortran
« Reply #6 on: December 25, 2016, 01:03:25 pm »
Yes that looks a lot better.
You could also move the VCC33 a bit further from VCC to connect the ground. (Between DSR and RTS)
« Reply #7 on: December 25, 2016, 01:31:58 pm »
This? Where the arrows are?
or the island?
« Last Edit: December 25, 2016, 01:34:30 pm by thomasb9511 »
« Reply #8 on: December 25, 2016, 01:47:29 pm »
« Last Edit: December 25, 2016, 01:59:30 pm by thomasb9511 »
Offline Fortran
« Reply #9 on: December 25, 2016, 02:21:51 pm »
Yes the last one is what I meant.  :-+
Offline technotronix
    • PCB Assembly
« Reply #10 on: January 14, 2017, 10:29:52 am »
Yes, It is true. Nice design.  :-+
Offline stefanh
« Reply #11 on: January 18, 2017, 03:31:00 am »
The fiducials and polygon clearance are a bit small.
I would generally make the pad 1mm in diameter and allow 1mm clearance all around. Also I would only put three of them on the PCB corners to help prevent the board being rotated 180 degrees assuming it was to be machine loaded.
There are many other fiducial best practices that can be searched for.
Offline richardlawson1489
    • PCB Assembly
« Reply #12 on: January 31, 2017, 11:49:17 am »
I like your design.
Offline Paulvanavesaath
« Reply #13 on: April 05, 2017, 02:06:32 pm »
Nice design,
Very good for a first try! :)
Just as a small addition to the already told items, you should check the layerstack at this moment you have a very thin PCB.
But that is probably not a concern right now.
you should try and avoid spikes in the top layer polygon like between the DTR and RTS signal. but again this is not an issue here.
Keep it up!
kind regards,
Paul
