Author Topic: Removing Thermal Reliefs?  (Read 2107 times)
Offline theatrical sceneTopic starter
« on: January 23, 2019, 11:18:13 pm »
I've seen that you can set up a rule to remove thermal relieving from pads by setting a rule (like in https://electronics.stackexchange.com/questions/165136/altium-polygon-pour-direct-connect-on-vias-relief-connect-on-pads) but I was wondering whether there is a way to do this from the editor to individual vias/pads without making a rule for each net?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Removing Thermal Reliefs?
« Reply #1 on: January 24, 2019, 12:45:04 am »
Nope!  Has to be by rule.
Or you can short over it with copper.  (Doesn't work on a plane layer, obviously.)
The next closest you might do is:
IsPad AND (Name Like 'R101-1')
or something like that.
Or the next better way, go into Design/Classes, put the pad in a new Pad Class, and query InPadClass('Direct') (or whatever you named them).
Seven Transistor Labs, LLC
The following users thanked this post: theatrical scene
