Author Topic: Altium stuck at creating project  (Read 2762 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
« on: April 12, 2020, 02:56:17 pm »
Has anyone encountered Altium getting stuck at creating new projects? I can open, view, modify and save projects.
If I really want, I can copy an old project file to create projects, but I can't create brand new projects from file menu.
It was working just a few days ago, but it suddenly stopped working today.
I'm using Altium 20.0.13, Windows 10 18363 64-bit with EN-US locale.
Tried to reboot and purge Altium preference files, performed a fresh activation and configuration, with no help.
I can see the create new project window, but once I click create, Altium hangs, and the new folder appears in Explorer, with no contents.
Altium ceases to respond to anything, including clicking of the red close button. I can only close it in task manager.
Any suggestion? Should I perform a clean re-installation or should I do what?
« Last Edit: April 12, 2020, 03:06:47 pm by blueskull »
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Altium stuck at creating project
« Reply #1 on: April 13, 2020, 02:09:00 am »
Do you have networked template files?
“They Don’t Think It Be Like It Is, But It Do”
Offline Psi
« Reply #2 on: April 13, 2020, 02:43:00 am »
Pretty common to get those sort of issues in apps if you have worked with files over the network and that server has suddenly disappeared.
Offline olkipukki
« Reply #3 on: April 13, 2020, 01:07:47 pm »
Same here
Okay, I gave it a bit more patience, and it responded and worked after being stuck for a minute or more. This IS a bug!
Around 15 seconds to create a new empty project (only project file is created), 2nd new project - no delays
Offline olkipukki
« Reply #4 on: April 13, 2020, 03:40:02 pm »
Exactly the same today. Seems like some evil Altium telemetry server went graceful downgraded globally.
I have a general issue sometime ago, but has solved with firewall settings.
https://www.eevblog.com/forum/altium/are-altium-services-down/
The project creation is not impacted at all  :-//
