Hit TAB and play with the measurements; or even better, hit ~ to see what keys are active (uh, miter size 1/2, gap size 3/4, amplitude ,/. and so on) and play around with them to see if anything happens.
There should be a length rule as well. You'll see the rule on the TAB dialog, showing which trace(s)/bus the length matching is referenced to. It sounds like this is working, because you got the right numbers in the tuning gauge.
