Author Topic: Same net track clearance during an interactive routing  (Read 1548 times)
Offline Vogelek23Topic starter
« on: October 30, 2017, 12:52:05 am »
Hello dear colleagues.
I have a serious problem with design rules in Altium Designer 10. I can't set up a fixed clearance between two or more tracks which belong to the same net. I want to draw an octagonal RFID PCB antennae (70x50mm outer and 30x10mm inner diameter). I have set a track width (0.35mm - critical) and a fixed clearance (0.20mm - critical) but when I'm starting an interactive routing, Altium does NOT keep that fixed clearance between the turns (I can easily make a short across all the drawn turns during coil drawing). I have switched a clearance rule to "Same Net Only" (under Design -> Rules) but it still did not avoid shorts during routing, so I have changed this option to "Any Net" - it now does not allow me to make a shorts between turns and seems to keep the clearance, but it also does not allow me to draw the rest of the turns!  |O
Does anybody know how to keep a fixed clearance between tracks with the same net during an interactive routing?
Offline Ice-Tea
    • Freelance Hardware Engineer
Offline voltsandjolts
Re: Same net track clearance during an interactive routing
« Reply #2 on: October 30, 2017, 07:01:44 pm »
Yeh, clearance rules operate between different nets, your working on the same net.
Maybe easier just to setup an appropriate grid or place snap points (point guides) before routing.
Offline Someone
    • send complaints here
« Reply #3 on: October 30, 2017, 11:55:24 pm »
