Author Topic: Altium: Using a Schematic + Layout as a part  (Read 2207 times)
Offline ripper_pcTopic starter
« on: September 10, 2015, 06:19:57 pm »
Here is my situation:
I have a schematic for a Buck converter - which I have laid out and tested. I now have to use this design in multiple other bigger boards and I do not want to lay it out again every time.
I was hoping there was a way that the schematic and the associated layout could be compiled into one component that I could add and use on all my other boards- Cadence allows one to do that, I am not sure how to go about it in Altium. Google didnt help much.
« Last Edit: September 10, 2015, 06:27:05 pm by ripper_pc »
Offline tszaboo
Re: Altium: Using a Schematic + Layout as a part
« Reply #2 on: September 10, 2015, 09:18:11 pm »
Thanks!
I read about them but they seem less useful than creating a part - since one has to synchronize the design every time you add a schematic and PCB snippet - and was wondering if there was a way to make a component / sheet symbol associated with layout.
But thanks for the tip!
