Author Topic: Irregularly shaped pads  (Read 6713 times)
Offline johndoe1395Topic starter
« on: May 05, 2012, 05:03:51 pm »
According to altium wiki (http://wiki.altium.com/display/ADOH/Creating+a+Custom+Pad+Shape), you can create custom shape pads by using various design objects to create the shape, then place a small pad inside to define the connection point. I created a custom footprint and did exactly that however the DRC shows errors at those points. What am I doing wrong? Is there any other option I need to check?
Offline free_electron
    • SiliconValleyGarage
Re: Irregularly shaped pads
« Reply #1 on: May 05, 2012, 05:29:18 pm »
that's normal. when pushing the netlist these bject do not get tagged.
run the DNU command. ( Design , Netlist , Update primitives from .. drat cant rmeeber what ti reads on themenu. the keyboard shortcut is DNU in the pcb editor
