Author Topic: Collaborate, Compare and Merge ISSUE  (Read 1620 times)
Offline YaSaRa_NTopic starter
  • Country: lk
  • I am an Electronic engineering newbie
« on: October 09, 2019, 09:15:07 am »
Hi !
I've been experimenting on team-collaboration using SVN version control feature  in Altium(using the in-built SVN ).
everything works fine except the merging a local copy with the current head revision in the repository.
following image shows what i get when i click "Click to show merge resolution view"  in the "Collaborate, Compare and Merge" panel.
as you can see the background is completely white and i can barely identify the content of the PCB. i tried this with Altium 18 ,19 and 20(beta).
the merging works without a problem but i can hardly see whats in there. Is this normal?
however there is no such issue in Altium 17.
is this a bug or have i done some thing wrong ?
Thank you.
