Author Topic: PCB editor: one object highlighted with brighter hue. How do I turn it off?  (Read 1129 times)
Offline TTAQTTopic starter
  • Country: at
Hi folks,
A component (or in this most recent incident a buried plane or net or something) is somehow always depicted in a much brighter hue than it normally is (blue, for bottom polygon fill in this case).  In the 3D view, all objects which would normally be in the way are cut away so that the object appears directly.
I keep accidentally hitting some keystroke or doing some misclick to produce this.  Does anyone know what this is and how turn this off?  I've been searching through the Altium documentation online in vain for hours.
It's gone again now because I failed to resave, so no pic sorry :-(
Online T3sl4co1l
    • Seven Transistor Labs
I forget if there's highlighting for components or other objects, that may've been added in 18+.
Net highlighting can be controlled on the PCB Panel.
Seven Transistor Labs, LLC
The following users thanked this post: TTAQT
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Like Tim mentioned it sounds like you are highlighting a particular net. This shortcut is ctrl+LMouse. The shortcut to clear any filtering or selection or highlighting is shift+c.
“They Don’t Think It Be Like It Is, But It Do”
  • Country: at
That was it!!  Thanks, it was driving me crazy.
Online T3sl4co1l
Oh yeah, CTRL+click highlights a net and ALT+click highlights a component.
I think I was confused by your use of "hue", which is color (red-green-blue).  The intensity is the luminosity, which is how this highlighting works.  (That leaves saturation, which is how intense the color is; masked objects are set to gray, i.e. zero saturation.)
Brackets [ ] change the background level while highlighted, or the | Snap | Mask Level | Clear | buttons in the bottom-right access menus for this (and snap things, and Clear is just SHIFT+C).
