Yes, of course. I am far too pedantic not to have build a series of perfectly (imho) formatted templates early on, heh.
The issue from this approach is that if I switch to [Project Documents] I can control the order but I only get one page per subsheet. For sheets that are stamped out multiple times with different values, it doesn't make any sense. For instance, the LDOs are all set for different output values. I've set the resistor's value to "RVAL" or something similar, and then applied the parameter "RVAL=10k" or the similar to the sheet symbol. When I print [Project Physical Documents] it does the value replacement when it generates the sheets and they all look correct.
In short, it looks like:
Top Level
Part
LDO
Memory
I/O
Misc I/O
Specifically, it doesn't make any notice of the fact there are 10 LDOs or whatever, let alone that they have different values.
Any other ideas?
