Author Topic: PCB footprint for a dome switch  (Read 1626 times)
Offline barbqman130Topic starter
« on: February 13, 2021, 11:03:56 pm »
 Can anyone explain how to create a footprint for a dome switch in DXP 2004?  Is there a component for this?
Thanks,
Dennis
Offline ajb
Re: PCB footprint for a dome switch
« Reply #1 on: February 15, 2021, 05:13:57 am »
It's the same as creating a footprint for any other component.  Have you looked at any of the wide range of library creation tutorials that are out there?  Where are you getting stuck?
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #2 on: February 15, 2021, 03:50:13 pm »
If you are refering to making pad shapes that are not circular or rectangular in nature, you can use fills/regions.
Draw the shape you want and then place a small pad within the shape on the same layer. During layout you may need to update primitives from connected nets (shortcut combo d -> n -> u)
“They Don’t Think It Be Like It Is, But It Do”
Offline kimlanbu
  • Country: tr
« Reply #3 on: March 16, 2021, 01:42:07 pm »
Find the switch in mouser and select one with 3D model and layout. It is the easiest way.
