Author Topic: Altium exclude schematic component from BOM, with grapichal cross over.  (Read 7991 times)
Offline halexaTopic starter
I have a board that on one variant alot of components shall not be included in the BOM.
I have change the type of these components to (Standard no BOM). But i would like to have an graphical indication on the schematic like in the attached pic. This I dont know how to do.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Altium exclude schematic component from BOM, with grapichal cross over.
« Reply #1 on: February 03, 2015, 11:31:56 am »
Select the respective assembly variant in the OutJob.  You can do this per-job at the top, or per item (on the right of each item that can produce variants, there is a drop-down selection box that is enabled when the "select per item" choice is selected).
Seven Transistor Labs, LLC
« Reply #2 on: February 04, 2015, 11:36:17 am »
Thank you for the answer,
So you cant do this in schematic editor, you need to have an associated PCB to the schematic?
Online T3sl4co1l
« Reply #4 on: February 04, 2015, 06:32:25 pm »
Thanks for the link, now things starts to get clear for me.
