Author Topic: Cross hatch rectangles over components in Altium Viewer  (Read 6209 times)
Offline jskoogTopic starter
« on: January 30, 2015, 07:06:03 pm »
I gave a client Altium Designer Summer 09 Viewer to check out a design. When zooming in on a PCB layout, cross hatch rectangles appear around the components. This makes it hard to view the traces. How do we get rid of these boxes.
Offline free_electron
    • SiliconValleyGarage
Re: Cross hatch rectangles over components in Altium Viewer
« Reply #1 on: January 30, 2015, 08:14:49 pm »
You have mechanical 1 on and what you are seeing is the part body .
O-L turn off mechanical 1 and or 2
« Reply #2 on: January 30, 2015, 08:30:09 pm »
Turning off the mechanical layers didn't help.
This shows the purple mechanical layers on. But when I zoom in further, the larger white cross hatch rectangles appear around the components. The yellow top overlay component outlines also appear, but when I turn off the top overlay, the white cross hatch boxes stay.
Offline DerekG
  • Country: nf
« Reply #3 on: January 30, 2015, 11:32:43 pm »
Actually just pressing the shortcut key "L" works :)
Have a look at the actual component in the component library itself. It might be a keepout area. If so, save the component with a new name, modify it (ie remove the keepout area), then use your new version.
You can also turn off the "Keep-Out Layer". Just press "L" to bring up the layer menu.
ADDED: The mechanical Layer is just an indicator for you. The Keep-Out Layer prevents the auto-router from using that area.
« Last Edit: January 30, 2015, 11:42:54 pm by DerekG »
I also sat between Elvis & Bigfoot on the UFO.
« Reply #4 on: February 02, 2015, 06:52:51 pm »
These rectangles are not keep-out regions and are not specific to a component. All components get the box when you zoom in. I've attached pictures of the display just before they appear, and after zooming in one step.
Offline ajb
« Reply #5 on: February 07, 2015, 08:02:25 pm »
Are there any active filters?
« Reply #6 on: February 07, 2015, 11:57:38 pm »
Playing with variants ?
Offline JDubU
« Reply #7 on: February 08, 2015, 12:30:55 am »
What happens if you click on the "Clear" button in the lower right corner of the window?
