Author Topic: Zoom into DRC error?  (Read 7038 times)
Offline Pack34Topic starter
« on: May 16, 2017, 04:41:14 pm »
I'm going through and cleaning up all of the DRC errors in prep for an order.  When I double click on an error it zooms me out and seems to attempt to center on the error. Is there a way to have it zoom all the way in for this so I can actually see where the error is?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Zoom into DRC error?
« Reply #1 on: May 16, 2017, 09:13:05 pm »
In the PCB Violations panel, there's a Zoom Level button at the top.  (A couple other panels have this too, like library view.) :)
Or double-click the error in the Messages panel, which I think defaults to a close zoom.
If the violation happens to be flagging a large polygon, you might simply get the whole polygon, which doesn't help much.  You may have to enter the coordinates in the description (J, L) to find it, then.
Seven Transistor Labs, LLC
The following users thanked this post: Pack34
« Reply #2 on: May 16, 2017, 09:19:47 pm »
That makes my life so much easier.  Thank you.
