I have inherited an altium design that has ~130 parts on the BOM. I do not have the library that any of the parts came from, so the only parameters that show up in the panel are the ones that the original designer put in their library. None of these parts have any max temperature data, which I would like to add as a column on the BOM.
I could go through each part individually and add the parameter locally, then regenerate the BOM. To save time, I would like to be able to select all the components in the design and add a "Max operating temp" parameter to all of them, then I can go through each one and quickly input what the number is for each part.
I cant seem to figure out how to add a parameter to all components, I'm only able to do it on each part individually.
Is what I am describing possible??
