The Component is split into several Parts. You are currently only seeing Part A.
You may want to go under Properties and select Part A, B, C.... and place them separately or create a whole new Symbol for the Component if you want all the Pins on one single Symbol.
With a Component with so many Pins I am not sure If that makes a whole lot of sense.
