Author Topic: Best Altium setup for creepage and clearance  (Read 2380 times)
Offline ricko_ukTopic starter
« on: September 22, 2020, 06:40:39 pm »
in Altium, what are the best practices to setup a project/schematic so that when you get to the PCB you have rules (or can set them up quickly) for creepage and clearance?
I am thinking perhaps setting up rules or classes or parameter sets in the schematic so they appear in the PCB?
Maybe attaching maximum voltages labels/classes/parameters to various nets and then define rules in the pcb between each of them (i.e. all combinations)? Or maybe there is a simpler way?
Are there any guidelines or examples?
Thank you
Offline ajb
Re: Best Altium setup for creepage and clearance
« Reply #1 on: September 24, 2020, 10:55:12 pm »
It would be unusual to require more than one or two sets of creepage/clearance rules on a single project, so I wouldn't stress too much about doing anything complicated.  Just define a net class to contain the nets that need special handling, use directives (with or without blankets) in the schematic to assign the class to the nets that need to be in it, and create PCB rules against that class.
Make sure to set your rule priorities appropriately so that the most strict requirements are the highest priority.
For example, if you have a mains-powered device, then you could simply set up a "Mains" net class and assign it to the required nets.  Then in PCB you might need to have a set of rules for creepage/clearance between nets that are both in Mains, and maybe more strict rules for when only one of the two nets is in Mains.  Simple as that.
You can also assign net classes in PCB, but it's generally better to do it in the schematic so that it's visible, and is less prone to getting lost when pushing changes back and forth between Sch and Pcb.
« Reply #2 on: September 26, 2020, 07:47:08 pm »
Thank you Ajb :)
