Author Topic: FunFact - clearance constraint between blind via and Fullstack Pad  (Read 1103 times)
Offline Kanc1erzTopic starter
  • Being a noob the whole life :)
Hello, I observed that TH Pad and blind Via has a clearance constraint even when the blind via is only on BottomLayer + one layer above and TH Pad is on TopLayer (on all other layers that pad has smaller size), as in the screenshot below :)
