Author Topic: Altium Pads/Hole Style  (Read 5186 times)
Offline brueTopic starter
« on: February 06, 2012, 08:24:22 pm »
Hi
I would like to Style my Pads like here:
http://de.wikibooks.org/wiki/Datei:PartialDrilledBoard.png
with a hole of copper in the middle. So it shoud be easyer to drill the holes manually.
Is it possible to make this?
Thanks
Offline peter_mcc
Re: Altium Pads/Hole Style
« Reply #1 on: February 07, 2012, 11:34:07 pm »
Do you mean a large pad and a small non-copper area in the middle?
If so, just make your pad "large" and the hole "small".
Peter
Offline Randall W. Lott
« Reply #2 on: February 26, 2012, 11:03:14 pm »
I would suggest using the octagonal pad style if you'd like to mimic this.  Be sure to create an annular ring large enough so pad breakout isn't as big of a problem with drill misalignment.
The annular ring is the pad area that is remaining after drilling.  A typical recommendation is to size the pad to be at least 80% larger than the hole.  I'd have it even larger if I'm drilling by hand.
- Randy
