Author Topic: Strange triangular cutouts appearing on polygon pour  (Read 1480 times)
Offline worldwideglideTopic starter
« on: April 11, 2023, 07:51:43 pm »
I recently inherited an 8-layer PCB that is supposedly "ready for manufacturing". However when taking a look at the copper layers I notice something strange... On every layer there are these triangular cutouts on the polygon pour in seemingly random places. Each layer has them in different places and I don't see any correlation between them and other objects. This is one of the internal signal layers:
Re-pouring the existing polygon or changing the polygon properties or rules does not fix it. The only way I can get rid of these triangles is to delete the polygon pour and place a new (identical) polygon pour.
Any ideas on what would cause this?
*Edit: I'm having trouble uploading the image
« Last Edit: April 11, 2023, 08:07:57 pm by worldwideglide »
Offline thm_w
  • Non-expert
Re: Strange triangular cutouts appearing on polygon pour
« Reply #1 on: April 11, 2023, 08:51:12 pm »
This is the gerber viewer right?
Does it show up like this inside Altium as well?
The following users thanked this post: worldwideglide
Offline Bud
« Reply #2 on: April 11, 2023, 08:51:34 pm »
Probably version (in)compatibility. Try generating Gerbers and see if the issue gets transposed on Gerbers. If it does then i guess you need to regenerate the polys.
« Reply #3 on: April 12, 2023, 12:09:44 pm »
Yes this is the gerber viewer. The issue shows up on both gerber and inside Altium.
« Reply #4 on: April 12, 2023, 12:11:04 pm »
It does get transposed unfortunately. I'll just assume a compatibility issue and that this was not an intended design decision!
Offline ajb
« Reply #5 on: April 12, 2023, 04:05:30 pm »
Are the existing polygons members of any classes?  You can check this in the object class explorer, Design > Classes.  Or does the behavior change if you rename one of the polygons? Polygon classes and names may be referenced in non-polygon rules that could affect polygon generation.
What does the outline of the polygon look like? If you change it does the behavior change?
Offline VK3DRB
« Reply #6 on: April 26, 2023, 05:39:46 am »
Try saving as a different Gerber format.
Or a different Gerber viewer. For RS-274X Gerbers, I use as free Gerber viewer called GerbV as well as Altium. GerbV does an extra sanity check and can be easier to see stuff than Altium's Gerber viewer. It is pretty simple to use, but works fine.
There are other free Gerber viewers around, like ViewPlot, GerberLogix etc.
Offline thm_w
  • Non-expert
« Reply #7 on: April 26, 2023, 09:32:48 pm »
OP already said the issue is also in altium.
